Oil Change ?
The bike has to be on a level surface, meaning not on a bike stand or a slant. That means have someone stand the bike up and you check the window. I used the entire bottle of Amsoil in my last oil change and the oil sat close to the top line. This is with the filter change of course. I like it filled up above the middle just for those occasional times I wanna bring the front wheel up. I hear wheelies can lead to oil starvation. Just don't go out of the lines. Going anywhere out of that limit is obviously bad but too much oil is a lot better then too little oil imo. O and remember to run the bike after you fill her up to see where it sits after the oil pump does it's job.
But yes, Level surface, and bike straight.
As dumb as it sounds I use the following technique:
Sit on bike as normal and hold it up level, and take a picture with my cellphone at the window. It lets me see the level quick without having to balance the bike while being on my knees trying to see it.
Its not difficult, just have some confidence. Put the bike in gear so it won't roll forwards or back. Leave the kickstand down. kneel down on the opposite side from the kickstand. Grab the handlebar and pull the bike up until you feel a balance point. At this point, your bike is positioned correctly to view the oil level.
If the bike falls to one side it will rest on the kickstand. If it falls towards you... well don't let it.
