OEM sprockets vs. +1/-2
Can't find the answer I'm looking for, so i'll post a new thread. My fuel economy is less than 30mpg. it might be my air filter, which someone suggested previously, but I also have the sprocket conversion done to my bike from the previous owner. Would this upgrade reduce my fuel economy a bit? I know it gives me lower-end torque but unsure if that is detrimental to my mpg. I'd like to have the bike up to the estimated 39mpg fuel efficiency if i can help it I'm not stunting this bike and don't think 'll need the conversion if its going to raise my fuel consumption by 8-10mpg.
Heres some quick numbers.
Stock gearing - 16/46 = 2.875 final drive ratio
Your gearing - 15/48 = 3.2 final drive ratio
3.2/2.875 = 1.11 So your engine will have to turn at 11% more times to travel the same distance as stock gearing, meaning approximately 11% more fuel consumption(its actually a little more because engines run less efficient at higher rpms) If you are currently getting 30 mpg, I would expect you would get at least 30 / (1-.11) = 34 mpg with stock gearing.
I have no experience with this in the real world, just messing around with numbers.
I highly doubt it will raise fuel economy 8-10mpg.
(17/44) / (16/46) = 1.11
Therefore when your on the highway you should gain about 11% fuel economy in theory so if your getting 30mpg you will get about 33mpg.
Edit: Kind of got beat to it.
boost fuel economy?
is anyone out there running taller gears to try and boost fuel economy or for other reasons? if so what kind of mpg are you getting? i have stock gears and get 45-50 mpg on my 2002 F4i. im shocked to hear someone only getting 30 mpg but maybe its all city driving or something.
Below 40mpg when the bike is being ridden easily means there is something wrong. How many miles on the bike?
I would say Im more shocked to hear 50mpg thn 30mpg
