sup guys been lurking for a while..i was workin on my bike and noticed something that looks kinda odd is this normal:
is there suspose to be a nut or pin there?
the other side has a bolt i assume is the axle bolt
and no doesnt require a pin. Actually you stick sumtin thru that hole to hold the axle to loosen the bolt on the other side, and then to twist/pull the axle out.
