noob help?
RE: noob help?
eteller, in race cars a windage tray is bolted into the oil pan at a level which keeps the oil from splashing up onto the crank. in addition they also use a crank scraper to (obviously) scrape the oil off the crank so it doesn't spin it off like taffy. does running high speeds low on oil for 500 straight miles sound like a good idea to you? ***.
RE: noob help?
RE: noob help?
ORIGINAL: ninetyfivehp
also, does anyone know where the oil pickup is located and how low in the sump. i like to do the occational wheelie and don't want to spin a main bearing. thanks F4i gurus
thanks, how much oil does it take to go from the bottom of the sight glass to the top when the bike is standing vertical like you're checking the oil? thanks a million.
anyone know? i'd like to stunt the bike a little and would like some piece of mind that 3.5 quarts of oil will keep the pick-up submerged when doin wheelies, etc....
RE: noob help?
RE: noob help?
ORIGINAL: eteller
Wrong, I raced both classes very sucessfully, everyone in showroom stock runs the oil low, every extra pony helps, and yes we got several seasons out of motor with no oil related failures. You're out of you're league here jr.
