non-iridium spark plugs
Hi! I just found out that the guy I got the bike from didn't use the proper iridium spark plugs. Instead, he installed some "equivalent" non-iridium NGK spark plugs
The bike runs fine from what I can tell... Probably not quite like it should, but I'm worried that I may damage the engine if I continue riding it like this. Any opinions?
Thanks,
D.
Thanks,
D.
RE: non-iridium spark plugs
And by change them more often he means almost never. My bike had 30k on it when i decided to change them but even then I asked myself why? It was more for something to do than anything......the chances of needing to change your plugs once let alone twice in the time you own it are VERY slim.
The plugs in there will work fine.
spark plugs go straight into the block, so if you over-tighten or don't mesh the threads properly it can be a big issue. So unless you bike's coughing I'd leave it alone. If you're really uncomfortable then maybe remove just one and get a feeler gauge to check if the gap's widened, and check if the plug has too much gunk layered on it. before you buy new ones.
Save your money for a couple of tanks of gas then. Like I said, mine was more of a "tune-up" which more of a way to kill some time in the garage when it was raining/snowing last fall..........otherwise, no need to bother. Not that they cant or dont go bad but if it's not running odd then it's likely sparking all it needs to.
