Night time + giant patch of pea gravel = sad :(
#31
My friend has improved his painting skills since the last time, so when the time comes to spruce my baby back up, it'll be better quality all around.
#32
In the first picture you posted there is a discernable difference in the color of your side fairing compared to your front fairing (side looks cream colored, the rest looks white). I was trying to figure out if it was A) all prepped the same, B) all sprayed at the same time, C) all painted the same # of coats. You gave me that answer.
#33
I don't know what rails you are using? I will go riding with ya and show you i can get in a corner just as low as you can with out hitting mine.
#34
#35
only sliders that do that are cheap ones or ones not made out of derlin. His slider did just as it was designed to do. SAVE the FRAME!!! Cages n rails were made for similar situations and those associated with stunting in parking lots. Stunting out on highways etc at high speed, they dont make anything for that :lol:
#36
#38
#40
Aken, dont ditch the bootleg exhaust. Simply unbolt the can, chop it a bit, and bolt it back in. You may be able to unbolt the metal part at the bottom, not sure though as I haven't taken mine apart. Also, can you PM me some info on your rotors (where you got them, cost, opinion, etc). Thanks!
