Next Project: Stainless Brake Lines
So what made you go with the dedicated each front line setup versus any other setup? Just picking your brain since I've been considering doing this as well
https://spieglerusa.com/media/upload...ing%202014.jpg
Now one issue I did run into after install was some minimal strain/rubbing on the throttle cables ONLY AT FULL LEFT STEERING LOCK at the double banjo bolt on the front reservoir... Its just the way the throttle cables are trained around the reservoir makes them rub a touch on the banjo bolt because it sticks out twice as far as original.
Sommes.
