Newb wants to add Power Commander III mod
Old 09-18-2006, 05:57 PM
SpiritBreaker's Avatar
Default Newb wants to add Power Commander III mod
I want to add the power commander III /w usb MOd
to cbr f4i 01.
Which one, or where would i buy the right one?
Old 09-18-2006, 07:26 PM
Default RE: Newb wants to add Power Commander III mod
ORIGINAL: SpiritBreaker
to cbr f4i 01.
Good prices on eBay, otherwise go to http://www.powercommander.com/buynowbike.shtml where you'll find 2001-2006 CBR 600 F4i is part #108-411
But I personally think you should max your bike out before you mod it out. As a self proclaimed noob you have no idea what that bike's limits are. Find out, then modify what you don't like because you know what needs to be changed, not because you read about it on some internet forum or you friend says it is great. IMHO
Old 09-18-2006, 08:08 PM
ORIGINAL: unrealtrip
Old 09-18-2006, 09:02 PM
ie ride the **** out of it and see what you don't like, then modify those things.
Old 09-18-2006, 09:11 PM
Agreed! You dont know what needs to be changed yet....... ride it for awhile then make the change if you dont like how the bikes running.
Old 09-19-2006, 02:40 AM
So can you explain to me the purpose of the Power Commander?
After reading, i thought it regulates the mixing of fuel in order to produce a smoother flow in terms or throttle and gasoline.
Old 09-19-2006, 04:50 PM
The main purpose of a Power Commander is to adjust the air/fuel ratio to accomodate modifications to the engine.
The side effect is that even with a zero map the Power Commander smooths out the throttle response.
What everyone is trying to tell you is that you need to learn to ride the bike first before you mod it. The F4i is a bad bike for n00bs to begin with. Throwing parts at it will make it worse.
Put some frame sliders on and spend your money on safety gear. No need to spend money on performance parts until your butt is armored head to toe.
Old 09-19-2006, 05:02 PM
+1
ORIGINAL: Blackdog F4i
i started on the f4i only cause i got a really good deal and i couldnt pass it up and ive scared myself more than once.
Old 09-19-2006, 06:52 PM
fishfryer527's Avatar
Remember that the engineers that Honda employs to design these bikes are very clever, they spend alot of time creating a well balanced reliable machine. Spend time riding your bike before you spend money changing things, it is a pretty amazing piece of work right out of the box.
Old 09-19-2006, 09:05 PM
If it ain't broke don't fix it !
Quick Reply: Newb wants to add Power Commander III mod
