New Stator?
cant do too much to help with the info that you've given but im gonna try to get you headed in the right direction.
aside from the spark plugs, you've leaned toward the charging system(stator and rectifier). neither of which, if bad, will prevent the bike from starting, assuming the battery isnt dead, but if dead then the bike wouldnt crank at all so im confident that you're charging system isnt the issue.
all that really leaves is fuel and spark.
plenty of videos on youtube on how to check for spark, if you dont know already. really easy to do.
as for fuel, pull a spark plug, if its wet and smells like gas...then that cylinder is more than likely getting fuel(do this while checking for spark).
if its dry, make sure the fuel line isnt pinched. make sure the fuel pump primes when you turn on the ignition(you'll be able to easily hear it). if both are fine then you may have clogged injectors, has the bike sat for a long period of time?
TL;DR
Does it have spark?
Does it have fuel?
Has it sat for a long period of time?
im wanting to know how you got to where you're at, troubleshooting wise.
aside from the spark plugs, you've leaned to ward the charging system(stator and rectifier). neither of which , if bad, will prevent the bike from starting, assuming the battery isnt
dead, but if dead then the bike wouldnt crank at a ll so im confident that you're charging system isnt the issue.
TL;DR
Does it have spark?
Does it have fuel?
TL;DR
Does it have spark?
Does it have fuel?
