New rider, a question concerning braking with my F4i..
Glad someone brought this up..When I need to stop quick I have the fishtail feeling as well...Ill try using less rear...I have been riding for about a year and have rarely had to stop hard so it has only been a rare occurance for me. Lack of experience or something wrong with the bike? Not trying to thread jack just seem to have a similar problem...maybe someone could elaborate a little more?
Hope that's what you were looking for.
Assuming everything is in working order, you guys prolly need to practice braking in a parking lot. It sounds like y'all are too heavy with your right hand. Sounds like you're grabbing the brake. Not enough to lock the front wheel. But more than enough to overload the front suspension while the rear hasn't settled.
Sportbikes get 90% of their braking power from the front. Applying front brake loads the front, lightens the rear, and it takes much less to lock it up or lose traction. The rear brake is great for grass and gravel, very slow tight turns and some advanced techniques, but in normal riding it can end up causing issues.
If you do a stoppie unintentionally, you grabbed too much front brake.
Cruisers and touring bikes need the rear brake much more than we do, and MSF teaches its use, but we're on sportbikes, which behave differently. In reality, on the street, I rarely even touch the rear. On the track, I use it, but we teach novice and intermediate track students to use front only. Not until very fast advanced training do we introduce the rear (and we don't introduce turning and front trail braking until experienced intermediates...and of course, don't try trail braking and advanced techniques except under the supervision of a qualified instructor, and always practice new techniques in a controlled environment).
Sport bikes have a relatively high center of gravity, which works to amplify the unwanted effects of braking. A cruiser, for instance, has a longer wheelbase, shorter overall height, weighs more, and places the rider further back between the wheels. All of this helps improve stability and keeps the rear planted. The drawback, of course, is agility.
Go watch a motoGP race. Half the time the rear wheel is just barely coming off the ground from braking with the front. Stop using your rear brake. Once you get completley comfortable braking with the front only then start practicing your rear application. The only time I put any real effort into the rear brake is when Im riding 2 up and need to stop very quickly.
There are practical reasons to practice using both brakes. In panic stops people rarely think. They rely on muscle memory. If using the rear brake isn't part of that muscle memory, it may not get used and they might not stop in time because of it.
MotoGP is a horrible example to a street rider. They have expertise most of us will never get close to, ride bikes that have been tuned beyond most our wildest dreams and ride on in an environment most of us won't get to. And randyjoy will tell you they do use the rear brake regularly. How they use it is an advanced technique that really has no application on the street and must be practiced carefully. But in this particular case, these guys are fishtailing when using both brakes in a straight line. That doesn't bode well if they have to emergency brake for real.
