new member, new issue with f4i
Old 04-28-2007, 02:35 PM
danteisme's Avatar
Default new member, new issue with f4i
ok im in the process of puttin my f4i back together after tearin everything apart for paint and tank repair. everything worked fine before the tear down, i took the pump out of the tank and put it in a sealed bag. last nite i put everything together, turn the key and turned the switch on for the pump and i heard nothing. so naturally i started gettin worried. i checked the wiring again and tried again...nothing. so i thought maybe my battery is too low for it to turn it on, so i blipped the starter real quick and the starter cranked right away. so then i took a lenght of wire and connected it directly to the pump's harness from the battery and the pump started whining. now im confused. connected straight from the battery the pump kicked on. what could i be missing here? what should i check next? there is only the one connector for the pump correct?[align=left] [/align]
Old 04-28-2007, 03:09 PM
Default RE: new member, new issue with f4i
so its not priming or what?
Old 04-28-2007, 03:11 PM
BIO's Avatar
BIO
BIO is offline
check the fuses
Old 04-28-2007, 03:16 PM
danteisme's Avatar
yes its not priming when i hit the on switch. but when i hook it up straight to the battery it primes. is there a seperate fuse for the pump? i checked all the fuses in the small fuse box, and the main one and they are all good
Old 04-28-2007, 03:37 PM
your flux capacitor is out, call honda for a new one
Old 04-28-2007, 04:04 PM
Um....is your kill switch off? That happens ALOT.
B.
Old 04-28-2007, 05:32 PM
danteisme's Avatar
nope, kill switch is not off
Old 04-28-2007, 06:57 PM
danteisme's Avatar
ok, when i got the key on and i flip the kill switch back and forth the pump doesnt nothing, doesnt prime. so heres my question, the pump Is not bad if when i hook it directly to the battery and i can hear it running, correct?
Old 04-28-2007, 07:38 PM
danteisme's Avatar
and one more question...is there any parts that absolutely need to be on the bike for it to start? right now, its pretty bare looking. heres a pic
http://img.photobucket.com/albums/v1...isme/bike1.jpg
only things that are on there since this pick is tank, airbox, and headlights becuase someone had mentioned that the headlights needed to be hooked up for the pump to turn on.
Old 04-28-2007, 08:42 PM
machino's Avatar
if it was me, and i've kinda been in your situation, i wouldn't worry about it too much until you had everything put back together. but that's just me. because yeah, who knows, there might be something that needs to be hooked up in order for it to start.
Quick Reply: new member, new issue with f4i
