New to Forum and a few Questions
Hey guys I'm new here and was hoping you could help us out,
My girlfriends bike is a 2001 CBR600F4I, I just put a 15 tooth front sprocket on and was wondering what the best speedo box would be the best for it.
Also does her bike have the plug in it for the cct? I mean the plug in the end that a bolt could be threaded into?
Also looking for ideas on a undertail for her bike.
thanks very much guys/gals
RE: New to Forum and a few Questions
you have 2 choices in speedo correction- yellow box and Speedo healer.
it appears that most people lean towards the speedo healer as it recalibrates dead nuts on, I
have read that the yellow box is not as accurate as the speedo healer.
i dont know about the cct
and yeah did you only replace the sprocket, or did you also replace the chain and rear sprocket, but only changed the size of the front?
It is usually not a good idea to only replace one part of the chain drive. a worn chain will wear out a new sprocket, and a worn sprocket will wear out a new chain.
