new F4i owner
Old Jul 22, 2022 | 04:22 PM
CarTooNHeaD's Avatar
Default new F4i owner
Hi all
new to riding the CBR600f 4i and ive noticed that on low revs / setting off its a bit splutery when setting off ( done oil , oil filter , coolant and all brake pads ) been reading up that it can be FPR or plugs and i want to fit iridium plugs but cant seem fo find the correct plug numbers for the NGK plugs before i go in and replace them and the air filter but main ones that come up after alot of searching is the IMR9C-9H
Old Jul 22, 2022 | 09:25 PM
dannoxyz's Avatar
Not likely plugs as when they go bad, it's always under difficult conditions, WOT @ high-rpms.
You've got some other issues: vacuum leak, TPS, MAP, ECT, etc.
Old Jul 24, 2022 | 10:20 AM
have to bring it in to the garage and get the plastics off and check things over , not getting any flashing of the F1 light so possibly a cracked/worn vac pipe
Bigbaldwin
Jun 17, 2020 05:58 AM
LilRed F3
Mar 7, 2012 03:25 AM
hmm
Sep 8, 2011 03:28 PM
scubba369
Jul 31, 2007 12:38 PM
Scrufdog
Jul 4, 2007 07:09 AM
