new f4i help
Old 11-26-2017, 11:11 PM
drock295's Avatar
Originally Posted by CaBaRet
Have a look here and download the Workshop Manual
https://www.manualslib.com/manual/12...0f4i-2001.html
Can you back probe the PINK wire at the ECU with ignition on to see what voltage you get
I thought if the pink wire didn't work that the fuel pump wouldn't prime when the ignition turns to on
​​​I'll double check to be sure though and let you know
  #22
Old 11-26-2017, 11:48 PM
CaBaRet's Avatar
Yes just being methodical and eliminating everything else
  #23
Old 11-27-2017, 03:32 AM
CaBaRet's Avatar
Originally Posted by drock295
I swapped both relays out they both click like they should as far as I can tell. Could the cam pulse be bad and still not code?
Just a thought, to test for codes again, crank the engine for 15 seconds, just in case it didn't pick up the fault on a short crank, then check for codes, will deplete the battery a bit but may find that code 18, or at least take it out ,clean it and re-install
  #24
Old 01-23-2018, 12:43 PM
drock295's Avatar
Update: got new injectors installed and tested while in fuel rail before putting back into motor the two outer injectors would squirt but not the inner two so swapped plugs and injectors untill all 4 fired and swapped a injector harness out to get them all squirting reset ecu and ran it 15seconds cleared all codes then checked and got 14 which is still injector 3 problem even though it did squirt. Any ideas? Book says a bad injector will cause a no start
  #25
Old 01-23-2018, 03:07 PM
CaBaRet's Avatar
Try resetting the faults again see if it disappears
  #26
Old 01-27-2018, 06:38 PM
drock295's Avatar
I tried running it till battery was almost dead resetting and testing for the light code 14 always pops up I even swapped injectors around again and saw all 4 squirting fuel. Could it be a pinched wire or loose pin at ecu?
  #27
Old 01-28-2018, 01:32 AM
CaBaRet's Avatar
Hi, so maybe now we should go back to the start ,and re-install the BAS ,and all other safety switches that you may have bypassed, Check the kill switch for 12v in and out
dr.squid
01-28-2018 04:42 AM
mattyggstick
06-20-2008 09:22 AM
smiley
12-15-2007 04:59 PM
the greeen lantern
07-13-2007 09:19 AM
Quick Reply: new f4i help
