New Clutch
Old Apr 15, 2007 | 02:35 AM
Stephens's Avatar
Default New Clutch
Well I found out its not my chain, I believe its my clutch. No matter what gear I am in, and I accelerate quickly the rpm's go up, but the bike does not accerate like it should. Has anyone ever replaced their clutch or is this something that should go to the dealer?
Old Apr 15, 2007 | 02:48 AM
holycrapitshassell's Avatar
Default RE: New Clutch
come on man, it takes like 10 minutes, its simple.
https://cbrforum.com/m_267295/tm.htm
i made that, check it out
Old Apr 15, 2007 | 03:30 AM
Stephens's Avatar
Dude thanks man, but I think its my tranny, cuz i slip while driving.
Old Apr 15, 2007 | 03:32 AM
BillytheKid's Avatar
checked the clutch cable? maybe it is still engaging when the lever is at rest. Otherwise it could be a worn clutch but nothing to do with the tranny. Tranny symptoms would be, getting to neutral alone, refusing a gear, crunchy noises.
Old Apr 15, 2007 | 03:34 AM
Stephens's Avatar
Is it possible I just need to adjust the clutch?
Old Apr 15, 2007 | 03:38 AM
ORIGINAL: BillytheKid
+1
and yea, you may check the clutch lever, it should have some freeplay (exactly how much is in your service manual) but the freeplay is a safety margin so you know that the clutch isnt being disengaged slightly even when you arent touching the lever.
Old Apr 15, 2007 | 03:45 AM
Stephens's Avatar
I have the entire manual 492 pages. And I printed the whole thing out. The clutch does have alot of play, I have to almost let it out completely before the bike will move forward.
Old Apr 15, 2007 | 03:48 AM
check from the engine side of the clutch on your Right crankcase cover. When i dismantled my bike it took quite a lot of playing to get it to engage right without any slippage. At most open the right crankcase and check your clutch, it only takes 15 mins. Check you dont have any broken springs, and check clutch thickness with a caliper, at least you will start ruling out some problems.
Old Apr 15, 2007 | 03:49 AM
Stephens's Avatar
Cool, will do that tommorrow. Thanks for the help guys.
Old Apr 15, 2007 | 06:04 PM
Stephens's Avatar
I readjusted my clutch, and it took care of it. Thanks for the help.
Zandaloo
Aug 22, 2013 03:26 PM
Bordo
Sep 21, 2012 07:33 PM
02f4irider
Mar 6, 2009 07:50 PM
red stinger
Jul 19, 2008 12:17 AM
cyber00677
Jun 23, 2007 06:17 PM
