New chain/sprocket issue
Trying to get new chain/sprocket combo (520 pitch - 15 front - 46 rear) on and appear to be a half link too long (or short).
First pic - Moving the adjusters all the way in is just this [ ] shy of getting it to where I can get to the next full inner link.
Second pic - I have to move the adjusters all the way to the edge of the "replace chain" zone to take up the extra slack.
I'm guessing I just need to get over my OCD and go with the latter setup but also want to make sure there is enough adjustment left to take up slack as the chain stretches...
Anyone else ever run into this issue? I swear I seem to have more issues that never get covered or encountered by the "It's so simple, only took me half an hour and I was falling down drunk!" crowd...
Are your adjustment markers for standard configuration ? I could well be wrong here but won’t it make the “new chain” bit move if your move away from stock sprockets with standard length chain.
There is somewhere on line, a guide to measurements over several links to tell when your chain needs replacing so you could combine that with the little bit of marker you have left. Or just move them to suit anyway lol.
i could be sooooo wrong it’s late here !
Like the black sprocket btw
I know that the guide is no longer accurate, but backing it out as far as it needs to be to take up the slack just doesn't give me much room to back it out more as it stretches. Seems it's just a bit too long or a bit too short... by half a link either way.
Appreciate the questions! Funny how the issue, when I'm looking at it, seems straightforward and then after I post up, you all come up with questions that never occurred to me...
I reckon I'll go ahead with moving the adjusters waaay back and just run it! The stock set lasted a bit over 20,000 so it's not likely I'll run through this one too quickly.
Thanks!
I think that might be the ticket! I was thinking I could run it as is for a while and, after it stretched a bit, take out a single link and re-rivet another master link. A longer bolt would definitely give me some more adjustment leeway.
Thanks!
If that is the case, then it'll be good to go. I went ahead and hooked up the master link and will see what happens!
Now, onto replacing the fuel pump regulator and checking my valve clearances. Yay.
Appreciate everyone's input!
