Neutral to 1st
Old 06-22-2008 | 10:08 AM
CBR Time's Avatar
Default Neutral to 1st
Ok this has happend only once or twice? im in N waiting at a light etc, try to engage 1st and she wont go? end up leaving in 2nd, anything to be concerend about here? again its only happened on very rare occasions, but thought id ask anyway. 2002 w 10200K's
Cheers
Old 06-22-2008 | 10:41 AM
sluijs01's Avatar
Default RE: Neutral to 1st
It's probably just the way the gears are laying since we have sequential gearboxes. Walking the bike even half a foot forward or back should allow you to drop into first. I typically make sure I'm in first just before I stop anyways, but every so often I decide neutral is necessary at an exceptionally long light
Old 06-22-2008 | 11:02 AM
CBR Time's Avatar
nice, thxs, ya same here, most often in 1st
Old 06-22-2008 | 11:39 AM
CBR Time's Avatar
btw nice color, lol same year same color go figure
Old 06-22-2008 | 02:00 PM
reaper2022's Avatar
I was wondering about this, too... I noticed it happening to me lately... I was worried my occasional clutchless upshifts were messing with the gears lol... but then again, I use the clutch for 1st and 2nd.
Old 06-22-2008 | 02:25 PM
RojerLockless's Avatar
when this happens rock the bike forward then back an inch or two while putting the bike into gear, it should work if that doesn't then slip the clutch out an inch or two then back kinda let it out then in ish you'll get used to it, it happens every so often nothing to get worried over
Old 06-22-2008 | 03:13 PM
mauthman's Avatar
shift with authority! if your not already...
Old 06-22-2008 | 04:52 PM
Wants a CBR's Avatar
If you're in say 5th or 6th come to a stop and thentry to go down through the gears it becomes hard to get into first. I learned that the hard way, from now on I go through the gears as I'm coming to a stop.
Old 06-22-2008 | 06:57 PM
jetjestor's Avatar
I have noticed this from time to time. All I do is let the out a little bit why in Neutral and then pull it back in again then it goes in fine.
Old 06-22-2008 | 08:44 PM
FFCBRf4i's Avatar
I have to admit that I've been experiencing a similar problem. I would be at a stop light and in first gear. Then I try to shift into neutral, so that I can rest my hands, but it wouldn't shift. The lever seems sooo stubborn. It wouldn't shift to neutral from first. I tried rolling the bike back and forth, but it didn't work. It didn't happen before either. I would be able to roll the bike and it would click right into neutral, but now it seems like it's more stubborn to shift.
Quick Reply: Neutral to 1st
