In need of a picture
Old 06-30-2011, 11:40 PM
Zero1080's Avatar
Default In need of a picture
I'm at a point now where I'm wiring stuff back up on my bike, and I need a picture.
It's of the starter relay, the one on my 05 right beside the battery on the left hand side if you're sitting on the bike. If the relay is sitting in it's 'place' (the little rubber grommet thing) and the two terminals are facing the left side of the bike, which side does the starter motor cable attach to, the left or the right? (meaning the cable that runs to the positive terminal of the battery is on the other)
Also, my relay fuse (little red wires with a whitish/yellow connecter) seems to be too short, short enough to where it looks like it'll be sitting on the battery. Is it supposed to go there?
Any pictures of that area will help! Thanks in advance!
Old 07-01-2011, 08:53 AM
nickp123's Avatar
is all this stuff relatively the same on the 01-03s do you know? if so ill help you out.
Old 07-01-2011, 09:59 AM
If all else fails you could try and use a voltmeter to check it out. If you do not havea volt meter I recommend going to even RadioShack and picking one up. They can cost an arm and a leg or they can be cheap, but the thing is they are indespensible when you are doing electrical work. I picked one up for $30 and it works just fine, it is not water proof and you do not see me running out doing highvoltage electrical repair, but it does just find for low voltage needs.
Old 07-01-2011, 07:25 PM
Zero1080's Avatar
Nick, I would assume it is. Bike Bandit uses the same diagram.
Stu, that's something I've been considering picking up. I haven't needed one yet, and hopefully won't. Plus since I don't actually have power to my bike, yet I know the parts are functional, it wouldn't really help :P
Old 07-02-2011, 01:51 AM
nickp123's Avatar
ok well i can throw up some pictures for you in the morning and hopefully theyll help
Old 07-02-2011, 07:45 PM
Zero1080's Avatar
Thank you!
Old 07-03-2011, 10:13 PM
nickp123's Avatar
sorry zero it rained all day so i couldnt get one for ya but it stopped now and i just got home from work so as soon as i get my lazy *** up ill post em.
Old 07-03-2011, 10:22 PM
Kuroshio's Avatar
Ugh... trying to find pics I took of my 06's starter relay before I hacked into it to install my alarm. Dunno where I stored the pics tho.
Let some of these rum & cokes wear off and I may be able to locate them. If not, I can take a pic with the alarm spliced in tomorrow. Remove the alarm wire and it'll be stock from the dealer
Old 07-04-2011, 12:46 PM
manny04's Avatar
I so know the feeling, and does it suck! Just took these hope any of them work for you:
Attached Thumbnails In need of a picture-dsc08244.jpg   In need of a picture-dsc08245.jpg   In need of a picture-dsc08246.jpg   In need of a picture-dsc08247.jpg
Old 07-05-2011, 01:32 AM
Zero1080's Avatar
^manny that helps a TON! thank you!
Juliet
04-15-2010 10:30 PM
gevo
03-24-2010 09:29 AM
CBR Jockey
03-25-2008 09:49 PM
herb600rr
02-22-2006 11:05 AM
herb600rr
02-20-2006 05:09 PM
Quick Reply: In need of a picture
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
