Need Help/any advice I can get. ?Fuel issues?
Pleas help me get riding again . I just bought my first bike 02 cbr600f4i 10k miles sat for a while so gas tank was a bit rusty. The guy I got it from said he put a new fuel pump and fuel filter and it turns on and idles great but when you give it gas it Boggs out. It wont die but it wont rev up past like 3-4k rpm. It can idle all day but it just wont revv up like it's getting to much air or not enough fuel. If anyone had any ideas please lmk.
ps I did the spark plugs oil change oil filter and air filter. Right after I did the plugs its revved up really good for a but next day still bogging. I checked fuel pressure regulator vacuum hose but no gas was dripping so I'm kinda stuck. I have a video of the problem on YouTube titled Crazy Cheap Cbr600
Thanks for help
Thanks for help
Thank you
So I ended up not ordering the fuel pressure regulator because they say you can check it by pulling the vacuum line and check to see if gas comes out while pump is priming. Tried it and no leak. Could it still be? Is worth it just to do it since it's not expensive or hard?
