Need Help - 2002 CBR600F4i Issues
Hey guys, sorry to join your forum on a bad note, but the 02 F4i I had bought about 6 months back is has been out of commission for nearly 2 months now, and I just can't seem to figure out what is wrong with it. So let me get into more detail about the issues.
So, I start off by turning the ignition on, the tach does its self test, all the lights come on, headlights come on and my FI light comes on. I did the test, codes 1,2,4,9,12,14,15 all came on, so I cleared the MIL and now only 14 comes on - the No.3 Injector
The main issue is that the fuel pump is not priming and no fuel is getting to my injectors, I thought maybe the BAS was an issue, so I believe I did the bypass correctly.
Still the same issue, I thought weak battery, so I tried jumping from my car (car off, of course) and no luck. Pump is getting battery voltage across the brown wires on the plug, and the pump should be good.
Letting the battery trickle charge for the next 24 hours
and this bike WAS a stunt bike, so the harnesses have been tampered with, but I did buy the bike running. Bike was in a slight off when my brother hit a curb going about 20, but the bike landed in soft grass, and did fire up after the incident, and for a month after with no issues. This is the bike I purchased for him to use, and would like to get it running again.
If you need any other info, let me know, I can be pretty quick with responses when I am at work.
Any ideas, hints, solutions are greatly appreciated, wanna get this bike up and running along side mine as soon as possible. (sorry I'm a gixxer guy )
if you download the service manual and tested the connector as it stated and you get battery voltage for a few seconds.
its the brown and green wires, and if your fuel pump doesnt prime then replace it, i doubt anyone will tell you that it should still be good after not priming.
I'll wait for someone who is experienced to chime in.
Pump runs just fine hardwired, the number 3 injector is indeed bad, no power getting to it. Would this cause the pump to not work and all injectors not to spray for combustion?
so whats wrong, the pump works, but doesn't work? it is direct current maybe the polarity is wrong when you plug it in.
I've got the situation handled, so no harm no foul.
Just say thanks & move on. No need to belittle someone who is trying to help.
I suggest your re-read the Forum Rules & Code of Conduct. You agreed to these when you joined. Respect goes along way in our community here, personal attacks do NOT & are not tolerated.
Since you've got it "handled", the thread is closed.
Resolved Problem submitted by Spook155:
The main harness was the issue, as the bike was previously stunted, and the harness was butchered in the process. Having eliminated the fuel pump, injector harness, fuel rail, and injectors as possible problems, the main harness swap worked. The bike has been up and running, solidly with zero issues for the past 6 months.
