need to get a Grip
Any longer than 40 mins on my bike and my hands go numb.....i think its mainly due to my old age but there must be a replacement grip I can use which will alleviate this problem. I have seen grip replacements range from $10 to $95 ...
Any experience and recommendations would be very appreciated |
renthal grips
get grips that are made of gel or foam
Originally Posted by greenc51
(Post 1092230)
Grips will help. I've heard good things about Renthal, too.
I love my Driven D3's, pricey but the best look as well as comfort, imo. Also look at your wrists and see if some adjustments to the bars are in order. You do not want any bend in your wrist, fore-arm should point straight to your knuckles. On a lot of the sport bikes, you need to be supporting the weight of your body with your belly not arms. Takes a while to build up the muscle (I'm still working on the same issue). DON'T ride with your elbows locked. this leads to poor control and the 'tingle' issue. Ern |
Originally Posted by MadHattr059
(Post 1092290)
I love my Driven D3's, pricey but the best look as well as comfort, imo. Also look at your wrists and see if some adjustments to the bars are in order. You do not want any bend in your wrist, fore-arm should point straight to your knuckles. On a lot of the sport bikes, you need to be supporting the weight of your body with your belly not arms. Takes a while to build up the muscle (I'm still working on the same issue). DON'T ride with your elbows locked. this leads to poor control and the 'tingle' issue. Ern That ^ +1 If you get tingly hands it is probably because of poor riding position. It seems quite unnatural at first but support your body weight with your body, not your arms. Locking your elbows makes you rigid on the bike and makes it more difficult to steer, makes the bike over-respond to small input errors and prevents the bike from stabilising itself over rough ground, bumps etc. |
These are some great tips!! I can see how my riding position is the underlying cause of my hands going numb, I def lock my elbows at times ,,,, I will focus on this and try to improve upon it. This is my first sport bike and it has taken a little getting used to....but at 44 yrs of age I am loving it.
I looked into the driven D3s and they look really good and if they help reduce some vibration then even better. |
Another thought as well, how do your gloves fit? Do they have a clean/smooth pad
for your palm? Look for bad pressure points, too tight/too loose? I have a problem with finding stubby fingers on a gi-normous palm. If the fingers fit, squashes my palm. If the palm fits...long, dangly fingers. Glove fit can affect the 'tingles' problem. At least that's been my experience. I'm a 52 year old by the way, until I got my new beastie, I hadn't ridden for almost 12 years. I'm definetly fighting the same battle you are. I'm also looking to get a bit of rear-set/riser over the stock clip-ons. That will take a bit of the belly work out. Did I mention, I was lazy? Ern |
having heavier bar end weights made of steel will cut down on vibration/buzz alot.
I got these ones off Ebay for cheap. They work good. Weighted Honda Bar Ends CBR 600 F4i F4 F3 F2 Black | eBay you can also get heavier ones from HVMP but they cost a little more. Hudson Valley Motorsports Parts - Motorcycle Handle Bar Ends for Honda motor bikes to Reduce Vibrations |
Originally Posted by Audi_F4i
(Post 1092562)
