need f4i clutch assembly help
clutch basket nut torque value?
clutch spring bolt torque value? how easily should the pressure plate assembly spin once its all assembled? i have assembled it all by hand without tightening down the springs and it seems to have some resistance. should it spin freely or have some resistance? the oem steel plates are beveled, which direction do they go in? does it matter which way the jutter spring is installed? meaning does it matter if the jutter spring is "opening" towards the engine, or "opening" away? thats all, thanks |
bump. please help. i need to get this f4i goin this weekend
every manual i have downloaded doesnt work, and I am not a retard, I use winrar and 7-zip daily, and have other manuals that work fine. pleeeeeeeease assist. |
There should be some resistance trying to spin it even with no pressure on the springs. It doesn't matter which way the steels are turned but I always turn them all the same way. The judder spring goes in with "open" end facing you (away from motor). Have to check manual for basket nut torque. Clutch spring torque on most is around 7-9 ftlbs. I use a 1/4" ratchet and just snug them. Those bolts are very soft and easy to break off.
hell yeah
muchos-focking-gracias! |
2 Attachment(s)
