is it neccessary to take off Fairing to Change oil?
on
1 Post
I pulled the left hand side fairing (sitting on the bike)when I changed the oil.. took all of 3 minutes to do and I was able to position the foil much easier.. plus I was able to get the filter wrench on without issue... I also removed the front "V" piece....
you might not have to do it.. but for the approx 5 extra minutes spent taking the stuff off will save you 10 minutes in fumbling your hands in there... my hands are kinda big and tough to get in there without cursing..
Its not the drain plug that is tough to get to.. its the filter area..
Adam
Adam
I just let the oil drip on the headers and let it burn off. I know lazy right ? But I be to busy watching tv or something while doing an oil change
I just finished a 2 hour oil change. The filter in there was the original owners and they had jacked it in good. The filter socket that's been mentioned slides right around when its that tight. We eventually decided to swallow our pride and take the fairings off. We didn't have a filter tool but a pipe wrench worked at that point.
Try the filter socket with the fairings on. If it gives you any problems take em off.
