my turn to do valves
plus its one less thing to put back on if your valves are within spec.
after you have measurements i would advise, having the notch line up to T and have cylinder 1's lobes face away from each other, otherwise rotate the crank again.
make a note where everything is at as far as the in/ex are on the cam gears and then remove the CCT, cam's, and don't let the chain fall.
my bike has 26,000 miles or so and clearance was last checked at 10k miles, i dont know if adjustments were made, i doubt it though. im not adjusting it this time.
