My Chain Snapped While Riding!!
um, yes well, that's him told!! ..lol
actually you may be doing him a disservice, if you look carefully at the visible teeth they look fine and the chain is not rusty at all ... often the front sprocket will get some light surface rust on it's surface as it's not that accessible normally and can look worse than it really is ... also a lack of lube shouldn't cause it to snap, no ... something went seriously wrong here and I would definitely want to know where and why this chain broke ... was it a split link or a badly rivetted master link or did it just snap in the middle for no reason.
Jules
Juliet is right about the sprocket. They are often found with surface rust on them, they are steel. You can have a properly mainatained chain and rusty sprocket. More than likely if he did not have a clip master link, I would say he had a very loosr chain. That can be a big problem. I'm not saying he neglected to keep up on maintence,it could be that he had a tire changed and some moron did not adjust it properly.
My stock DID died right around 20,000miles on my 06 f4i. I was really broke so I bought a cheap ebay 525, clip link and all. re-used the stock sprockets as they were not worn. That ebay chain lasted 2 weeks and about 500miles before it snapped a roller pin in half going down a back road at "higher" speeds. Lucky for me it just spat out the rear onto the ground. The clip link was still there, no problems! lol I was shifting from 2nd to 3rd and thought I had a false neutral until all 6 gears weren't working. Make sure you get a good replacement setup. I didn't skimp this time and feel much better for it.
Sorry, but I haven't really had time to take a real good look at it because I'm still a student and have been very very busy. However, when I got home today I saw my dad trying to get the chain off by cutting it. The center bolt was also off, but it didn't do anything, the jammed chain is still keeping everything in place very securely. My dad said that he had been cutting the chain for a good hour and a half and he BARELY managed to cut a couple halves off the chain. That chain is super tough so I have no idea how it snapped. I'm going to have to look for the master link when I have time. If it isn't there I'm going to assume that's what broke off. I'll report back asap. And thanks everyone for all your help!
