motor whines
Old Jun 16, 2006 | 04:39 PM
hnugen's Avatar
Default motor whines
I just bought a used 02 F4i with 20k on the clock.
the motor whines on start-up and after it's warmed up, whines in gear and out of gear and all the way from idle to redline. What could be the problem? Is this normal for Honda motors?
What is the idle and cruising temp of the motor? Mine sometimes goes to 232F while sitting at the light, after normal riding.
Edit: Found the answer to the temperature question.
Old Jun 18, 2006 | 09:35 PM
liquid_iq's Avatar
Default RE: motor whines
dude let me know if you find out about the whine. i got an 02 f4i as a track bike in addition to my 05 f4i. the 05 has a slight whine at all rpm, but the whine in the 02 is obnoxiously loud. i posted a question and got one reply, the poster said to use the stick method to try and locate where it is originating.
other suggestions center around the cam chain and the bearings. apparently bearings will whine if they are damaged.
600F4inoober
Jun 7, 2010 01:30 PM
TheX
Sep 27, 2007 08:01 AM
Billy Boots
Apr 4, 2007 04:50 PM
thebradster
Sep 13, 2006 08:02 PM
Gray6F4i
May 8, 2006 01:35 PM
