MIL Code 34
Old Jan 16, 2007 | 01:05 PM
natlbnldr's Avatar
Default MIL Code 34
Hello all. need your help please. My MIL light stays on while I'm riding. Once I stop and put the kickstand down, a code 34 flashes on the MIL. I have the service manuel but it doesn't say anything about a code 34. Does anyone know what this is? Bike seems to run fine. I did notice a slight hesitation in my throttle responce but overall the bike runs fine, this code is just throwing me. Any help would be appreciated.
Old Jan 16, 2007 | 02:12 PM
Ruftags's Avatar
Default RE: MIL Code 34
what year is your ride?
Old Jan 16, 2007 | 02:13 PM
natlbnldr's Avatar
I have a 02.
Old Jan 16, 2007 | 02:20 PM
Ruftags's Avatar
Mine is and 02, are you seein this on the display
Old Jan 16, 2007 | 02:22 PM
natlbnldr's Avatar
no it's going through the blinking sequence. 3 long blinks and 4 short.
Old Jan 16, 2007 | 02:26 PM
Ruftags's Avatar
First guess would be an 02 sensor(oxygen) in your pipe. I will check my manual 2nite after work and see if mine says about that code.
Old Jan 17, 2007 | 06:56 AM
Ruftags's Avatar
I looked this morning for the code and had no success, you may need to take to a dealer(dirty word). and have them put on a diagnostic computer. Sorry.
Old Jan 17, 2007 | 11:31 AM
natlbnldr's Avatar
Yeah, no luck on my end either. Thanks for checking.
Old Jan 17, 2007 | 07:44 PM
meangreenturbo's Avatar
I was getting the same code you are. Week later ecu took a dump. Got a new ecu and no code.
Old Jan 18, 2007 | 02:43 AM
woogie's Avatar
It does make some sense that it is some sort of an ECM problem. MIL code 33 is for the EEPROM, with a possible remedy of replacing the ECM. All of the other codes are grouped together (12, 13, 14 and 15 for each of the fuel injectors for example).
Just a guess, but it does make some sense. It might even be worth giving the "Short service connector with jumper wire" option for MIL code 33 to see if it will reset.
Totally guessing here, obviously.
vtece
Jun 15, 2012 03:07 AM
Nealio240z
May 13, 2008 12:32 AM
aProblem203
May 1, 2008 09:45 PM
KRiS
Oct 1, 2006 12:25 AM
Spyder14
Jun 13, 2006 09:10 PM
