Melted gauge: A warning to F4i owners (and others)
Well it happened.My Puig db dark smoke wind screen melted my gauge cover,and I've been so carefull too. A couple of weeks agoI had a Dr.'s appointment in another city about1.5 hrsaway. I left the bike on the shaded side of the building which I thought was the north sidebut I mis-judged the sun's direction of travel. Ironically, It was oneof thefew times I didn't back into a spot.
Here is the result.
It may not look like much but the raised ring around the tach is quite distorted. For thoughs of you who don't know, you mustn't allow the sun to shine toward the underside of the wind screen. The sun's rays will be focused into a narrow beam which will be cast downward toward the gaugesmuch like a magnifying glass, then, if exposure is long enough the above picwill be theresult.
Here is the result.
RE: Melted gauge: A warning to F4i owners (and others)
ORIGINAL: FLYOU
where was the sun's position that caused this to happen? i'm assuming you had the nose pointed toward the sun...
04 CBR, I already have a replacement coverin the works, and a local tint shop tells me they can apply a certain film to the inside of the windscreen that will eliminateproblem and not change the look of the screen. Hahahaha ya, I'm fussy
I always lay a rag over my my gauges if its outside..Cheap insurance..But i have since taken my Puig DB off(look good on the bike but actually made my wind worse on my highway rides.
Ended up taking it off and getting a zero gravity touring shield(fit like stock and a LOT less wind than the DB on the highway-plus getting it on clearence from zero gravity for 25.00 didnt hurt either) It just doesnt look quite as "mean" as the DB.
ORIGINAL: Twiztid CBR
Thanks but it could have been alot worse.
Twiztid I'm not trying to start a fight, I'm simply curious.
ORIGINAL: white99gt
