Mechanic question
Mechanic question
So my bike has recently turned 12k miles and it's started to have a rattle around 5-7k rpms. I thought of course that it was the cctl but when I called and talked with a local motorcycle mechanic for a quote on it he said that its probably not the tensioner but the cam chain itself and he swore by it... I'm not sure what to think now. Am I right thinking its the cctl?
Without being there, it's hard to do an accurate diagnosis.
However cam damage is extremely rare, especially given the miles listed.
I imagine the mechanic is refering to cam/valve adjustment.
Which is possibly due as scheduled maintenance at that mileage.
However, I don't see that as causing the noise described.
If you're going to refer to someone local to diagnose/fix the issue,
I'd get a couple of opinions, as mentioned above, by another poster.
The CCt replacement is a cheap/easy job, and certainly won't hurt
either you budget or the bike to do as a step in correcting/diagnosing the issue.
If you choose to DIY.
Ern
Ern
