May sound dumb but would like an answer...
I have only been riding for a few weeks and was wondering if I am sitting correctly because my *** has been killing me. I have been sitting pretty close to the tank and the seat is more narrow in the front so it hurts. Today I tried using the back section which is wider and my *** was better but I feel a little ackward. Is there a correct riding position? Using the back is more comfy but I feel wierd....
Guest
Posts: n/a
It's like riding a horse. If your unused to the position and motion it'll get sore after awhile, you won't notice it after you've ridden longer. As for proper position, it's different on most people due to different shapes, sizes etc. Try hugging up to the tank then sliding back a few inches, closer to the tank than the back but not touching it. Thats where I usually end up when I'm just cruising around, not riding aggressively.
Hey J, the only dumb questions are the ones you already know the answers to! I'm fairly new to the 2 wheel world too, I did what Hang said and found it more comfy to scoot all the way back. Less stress on the jewels, plus I'm built like an orangutan (my knuckles drag the ground when I walk)lol. Not really but its the best description, I'm 6'3", 190lbs and need a 3X to fit my long *** arms, if I get anything to fit my chest, the sleeves only make it to my elbows. Just sit where you fell most comfortable (less painful) and get used to it so you dont feel so wierd. Become one with the machine, there's alot more important sht to worry bout (IDIOTs in cars) than how your *** hurts. Once you get comfy on her, work on practicing countersteer, it sounds stupid but it works. Who'dve guessed you need to steer right to turn left? There's a write up that explains it all. Probably shoulda left that for another post. OL. Ride safe bro.
yea its more comfortable to scoot back
but while riding i always end up sliding forward on accident
but def try to stay slid to the back if your not too short
it makes it more comfortable like you said, because its wider
and yea it will def get better as time goes by, although i never really noticed any soreness
You should be off the seat if you're riding hard... Besides, being up further when riding hard is better - that way you're center of gravity is further forward, and lower (due to the slope of the seat).
Try adjusting the bars back and up a little.
Just loosen the lock bolts and rotate them back toward you a little. You can also raise them slightly. There's a circlip in a groove at the top of fork tubes, but it can removed and the bars brought up flush with the top of the fork tube. Check for clearance against the tank and fairing lock to lock.
It doesn't take much to make a difference in comfort. If that doesn't help, try a custom seat. I had mine done my Sargent and I use by F4i for long tours.
--Paul
--Paul
There is only one correct riding position when fast riding: knees locked into tank so that you don't slide foward when braking. For town riding, I suggest you find what's most comfortable but even then you might need to brake suddenly and if your kness aren't locked in; you ......... brake ......... and smash your nuts on the tank. For me, a relaxed town riding position just means that I don't press very hard on the tank with me knees, but the clinch is there just the same.
