majorly screwed up, over tightened water pump drain bolt...
ok so I over tightened the water pump drain bolt, I didn't know it was so easy to break
I over torqued the water pump drain bolt and it broke in half, i.e. part of the screw is still in the screwhole.. I think I need a die/tap kit, anyone got any advice? I guess worse case, if I can't get it out, I'll have to replace the water pump, how hard is that??
in panic mode right now...
here's a pic
here's a pic
Bummer!
Should be a fairly simple fix though. First, take a deep breath and don't panic.
Next, buy a set of ezi-outs.
Then you drill a small hole in the centre of the broken bolt, insert the correct size ez-out, carefully wind it in (anti-clockwise) until it takes up, then unscrew the broken bolt remnants. I'm assuming you did not use any thread lock etc.
Do a search on how to use them (Google is your friend).
Cheers, SB
Cheers, SB
Cheers, SB
and worst case, replace the water pump??
btw, thanks for the quick and helpful responses, this forum is amazing
You shouldnt have to replace the water pump.
It is a relatively easy method to remove the bolt remains. Often when I have broken a bolt and intend to use the easy out, the left handed drill will wind out the remains when I'm drilling the ezi-out pilot hole.
Just be careful of the threads in the hole.
Cheers, SB
Cheers, SB
Yeah I'm with the others. Just take a small flat head screw driver and see if you can get it out by turning it counter clockwise. If you can't get a bite on it then take a hammer and gently tap on the screwdriver to see if you can knock a slit into it so you can get a bite on it to unscrew it. Just had something like that happen to me and the flathead screwdriver works almost every time.
Oh and if that doesn't work then you can try to pick up an extractor bit from auto zone or advanced auto parts.
