lubing clutch and throttle
Old 09-05-2009, 01:23 AM
Default lubing clutch and throttle
what kind of grease u use for clutch and throttle? any one lubed them before?
Old 09-05-2009, 07:41 PM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
You can lube it with just about anything; ATF fluid, WD-40, chain lube, motor oil, ect. The main thing is that whatever you decide to use, has to be viscous enough to travel from one end of the tube to the other. One method I've heard of is to take a sandwich bag, cut the corner off, slip the pilot hole through the opening, wrap a rubber band around it and fill it with your lubricant of choice. Work the cable back & forth until it reaches the bottom end. Your other choice is to buy some cable lube, and utilize the tool below to inject it into the cable.
Source:http://www.dansmc.com/cables.htm
Old 09-05-2009, 09:32 PM
hey thanks
is it difficult to take the clutch and throttle cable off? what about re-assembling does it change in any way where u would have to adjust it back to before? thanks.
Old 09-06-2009, 06:34 AM
Incognito's Avatar
The clutch cable is real easy, but the throttle cables are a major PITA. With them, you'll have to remove the airbox, get to the throttle bodies and remove the slack from the cables, then you can remove them from the grip itself. As for adjustment afterwards, it's really easy & straight foward.
MattSD
08-08-2013 11:49 AM
knight202
06-27-2013 02:16 AM
Incompatible
09-01-2011 02:48 AM
Chunk3rs
09-10-2007 05:25 AM
Mikes03954RR
07-30-2007 03:20 PM
Quick Reply: lubing clutch and throttle
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
