Low fuel indicator not working
Old 02-03-2015, 11:49 AM
ny rider's Avatar
Default Low fuel indicator not working
Hi Guys,
I have a problem with my 2006 F4i.
My indicator comes on when I start the bike and it does the self check then goes off. The problem is, it WILL NOT come back on even when the fuel is low. Found that out the hard way. Is it the sensor? Can it be replaced? or is it part of the fuel pump assembly?
I know for a fact its not the fuel, I actually rode the bike till it was dry in hopes that the bars would show up.
Old 02-08-2015, 02:13 PM
I would pull the pump and make sure nothing is stuck or something. I honestly am not sure if its separate, on cars its always part of the pump. On my 06 I've gone till the bars were all blinking empty then another 40 or so miles, so its not like the thing is accurate to begin with lol
Old 02-09-2015, 09:31 AM
ny rider's Avatar
Thanks bored, I will try that.
I know its not very accurate, but the warning beats getting stranded which has happened to me already.
Old 02-15-2015, 07:35 AM
Retired Super Moderator
There is a procedure for checking the operation of the Fuel Reserve Sensor. It's on page 19-18 of the shop manual. Here's what it says.
  1. Disconnect the fuel reserve 3P black connector and short the wire harness side of the connector Brown/Black and Green/Black with a jumper.
  2. Turn the ignition switch to ON and make sure the fuel reserve indicator comes on with the side stand retracted (UP).
  3. If it comes on, replace the fuel pump
  4. If it doesn't come on, check for an open or short in the wiring harness.
Old 02-16-2015, 11:28 AM
ny rider's Avatar
Default Thanks
  1. Disconnect the fuel reserve 3P black connector and short he wore harness side of the connector Brown/Black and Green/Black with a jumper.
Thanks idodirt,
I really need a shop manual.
Old 02-16-2015, 02:43 PM
You can download it from the owners manual links thread on this forum in general maint.
emefef
09-11-2012 02:58 PM
dylan
03-06-2010 06:47 PM
lax4ever
08-31-2009 07:22 PM
mxpunk
10-13-2008 10:43 PM
jimmy_gr
12-15-2005 03:53 AM
Quick Reply: Low fuel indicator not working
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
