license plate light, which wire to tap into
Old 05-19-2010, 08:07 PM
Default license plate light, which wire to tap into
ok so i was looking for that white plug so i can tap in my license plate light, but the issue is.... i dont have one...., the guy have it before me have it all hack up, there's no plugs there at all, so which wire can i tap in to get power?
thanks
Old 05-19-2010, 08:18 PM
Turbulenz's Avatar
Official Welcome Crew
check the harness (or mess of) wires at teh rear that tree off to the rear turn signals... it should be in that subharness I believe..... check the wiring diagram in the manual.. I have it in pdf on my other PC if you need me to check..
Adam
Old 05-19-2010, 08:29 PM
Kuroshio's Avatar
Taps directly into the power and ground for the rear brake light. Constant power when key on is Black / Brown. Ground is Green.
Old 05-19-2010, 08:30 PM
axsys's Avatar
yep, there is actually a license plate wire back there. it should be a brown and black wire for the positive, and a green for the ground.
Old 05-19-2010, 09:50 PM
ok i find a plug under the seat that have a brown wire and a green wire and some kind of plug but when i tap into it, i get power but not bright at all, and when i start my bike my FI light would come on, and if i unpulg it then the FI light goes off, can someone tell me what that plug that is and why would my FI light comes on?
Old 05-19-2010, 10:14 PM
Kuroshio's Avatar
It'll be back in the tail by the brake lights. And the wire is black with a brown stripe down it.
Old 05-19-2010, 11:08 PM
axsys's Avatar
that is a service plug for the ECU. you dont want to mess with that....
Old 05-20-2010, 12:13 AM
ohhhhh opps, i didnt mass anything up right?
Old 05-20-2010, 12:14 AM
so i am looking for a black wire with a brown stripe down it, then a solid green wire?
Old 05-20-2010, 08:00 PM
axsys's Avatar
yep, might be a brown with black strip, im not sure. there should be all these wires back there: 2 wires for left turn signal, 2 wires for right turn signal, 2 sets of 3 wires for each taillight bulb, and 2 wires for license plate light. use your test light on any of the sets of 2 till you find the one that's not the turn signals
Quick Reply: license plate light, which wire to tap into
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
