License plate leds?
I have a rear mounted swing arm license plate frame due to my hotbodies undertail. My question is, what options do I have as far as getting some light on the plate? I obviously dont care, but the boys in blue seem to have an issue with not seeing my plate at night. I found these :
LED Tag Boltz http://www.customdynamics.com/Images/tagboltz850.jpg Is this something you would recommend? My license frame is arched so a normal square/rectangle frame would not mount onto it. And my concern with these would be running the power and ground wire up the swingarm and to the bike ( which would look tacky ) I really appreciate any ideas or comments guys, Thank you! |
thats really your only option, just wire them up to your license plate wiring from the factory
yep really easy install.. i got those in blue at a local bike shop...
I was considering those too. I have my plate mounted on a bracket on the right side (axle bolt) of the wheel and was thinkin of running it through the inside of the swingarm to the battery and hooking up a switch to my cluster to control power. But I'm curious as to how they look. Good luck with yours. Hope to see some pics.
Thanks for the comments, I think I will take the advice running it behind the swing arm and wiring it to the stock rear wiring ( running lights ) coming from the axel bolt, I will prolly tape it with black electrical tape to blend it in, and protect the wiring aliitle. Thanks guys
Use black duct tape and/or zip ties. Electric tape won't stand too well. I've been riding without a L/P frame light for over two years and havent been pulled over. I figure I'll wait till I get pulled over, lol.
NOPE!!! that's not your only option
Check out TRIPAGE stuff he has a great LED Licence Plate Frame with built in LED's VERY clean look I have it on my motorcycle. |
Check out TRIPAGE stuff he has a great LED Licence Plate Frame with built in LED's VERY clean look I have it on my motorcycle. http://tripageled.com/os/images/IMG_1125.JPG and here is the link http://tripageled.com/os/product_inf...roducts_id=153 |
Originally Posted by jasonb
(Post 1022407)
Check out TRIPAGE stuff he has a great LED Licence Plate Frame with built in LED's VERY clean look I have it on my motorcycle. http://static.kneedraggers.com/image...85d_detail.jpg This is what i have, but in black |
heat the plastic up a bit and it should conform to the curve of that plate holder.
