license plate bolts
The license plate hot wire is the brown/black wire, use that for the positive side of your light. The solid green wires (there's either 3 or 4 of them) are the ground wires, just use one of them for the ground side of your light. Now your light will turn on/off with the key and there will be no need for wiring in a new separate light and fuse.
You have the bracket that goes on the rear axle? If so then your plate is on the left side, correct? That's what I have. I got a license plate light from Cycle Gear with the double-sided tape on back. I mounted the light up in and on the rear-most part of the chain guard, then took a zip tie around the outside of the chain guard which makes contact with the light so to make sure the light stays in place. I ran the wires through the inside of the chain guard out of sight, all the way to the front and then jumped from there and wrapped around the frame up to the subframe and toward the back of the bike to the wire harness. I used good, sticky tape to hold the wires inside the chain guard, cleaned the guard really good first so the tape stuck with no problems.
6doubleohf3
How-To: Mechanical
05-01-2009 01:59 AM
