License Plate advice.
hey guys, I've just installed an under-tail and a rear seat cowl and I really like the look of my bike from behind. I have also installed an HR1 exhaust which allows me to remove the passenger footpegs due to its length and also there is no passenger seat. ANYWAY, I was thinking in mounting my plate on where the passenger foot-pegs used to be. As in using those same mounting points and have the plate "flush" with the rest of the bike. Is it legal?
Here is the law statutes for my state. (scroll down to #5)
Tom McGrath’s Motorcycle Law Group : Virginia Motorcycle Statutes
As far as I can read there is nothing concerning its axial placing whatsoever. Give me your opinion, and thank you for your time.
I was just pulled over the other day, right after i did my DIY fender eliminator.
The trooper said it wasnt my plate as much as the missing fender, "rocks kick up and hit his windshield". Then he showed me his chipped up hood from "chasing bikes all day" as he put it. He said "if it's not stock it's illegal." BS!!!
I got a work order to fix in 10 days. Took the bike to the county precinct and they signed off without even looking at the bike!! I didn't change anything!! So i'll just carry the signed work order around in case it happens again.
You statutes state, "In a position to be clearly visible". This means by law enforcement behind you. If you mount L or R, it won't be visible from behind. It must face back.
I'm pretty sure that statute stresses that it's visible and most people don't run your plate from beside you... so yes, more than likely; you will be stopped and stopped often if you have your plate facing the side of the vehicle. That'd be equivilant of putting your car tag on your driver's side window. How do you think they'd feel about that?
6doubleohf3
How-To: Mechanical
05-01-2009 01:59 AM
