<a href="http://s4.photobucket.com/albums/y13...nt=bike4-1.jpg" target="_blank"><img src="http://i4.photobucket.com/albums/y13...18/bike4-1.jpg" border="0" alt="Photobucket"></a>
<a href="http://s4.photobucket.com/albums/y13...rent=bike3.jpg" target="_blank"><img src="http://i4.photobucket.com/albums/y13...rl18/bike3.jpg" border="0" alt="Photobucket"></a>
Here is mine. Torn down for the winter.
[IMG]local://upfiles/31652/58D843A34EF34346B32FFB776BF82C3C.jpg[/IMG]
[IMG]local://upfiles/31652/665508E9E32A499592EA4E0E1E8DE7AA.jpg[/IMG]
Please give me some contact info on those headlights. I wanted that!!! Could you take some up close pics of the housing like so we can see the inside of the light.
ORIGINAL: 04_CBR
http://www.rondosa.ca/F4i_R6Projectors.htm
Btw, theres a process in that DIY that requires you to remove the projector cover away from the housing. Well she instructs you to use the baking method, which requires you to bake the f4i and r6 housing in order to remove the glue that bonds the housing and the projector cover. I did away with that and I used a heat gun (i bought from home depot for 20) to do it instead.
Anyway, read that DIY and if I can assist you in any way just let me know. I will be more than glad to help you. Heres a list of what you may need.
1) Tool set (to remove headlight assembly)
2) 2003 R6 headlight assembly
3) Heat Gun (home depot)
4) Dremel tool (cutting disk and drill bit)
5) Epoxy
Other items may be needed, just refer to the diy.
Good luck man. I will try to post a close up pic but i cant make any promises
