legal integrated lights?
So i'd like to do the "DIY integrated tail" on this forum to my CBR but i've been thinking about the legality of it. if I cut off the fender and mount my license plate directly under the tail light on the remnants of the fender, will illumination of the plate be an issue? I heard that your license plate is required to be lit by a white light, but if I remove the fender the light that illuminated the plate will be gone as well. anyone have a way aruond this or do you just hope a cop doesn't notice?
Illumination of the plate is one issue. Most jurisdictions, the laws state that the plate must be lit at all times with white light, and that the light not be visible directly, just off the plate. Another problem with the integrated tail is the (also most laws require) minimum distance BETWEEN the rear turn signals. This probably varies depending on where you are, but most places they're required to be something like 10" to 16" apart.
you can buy the plate light of tobefast.com. Thats what I did just to be safe. Just ordered it so I havent actually got it on yet.
Check it out - http://www.tobefast.com/led-incandes...r-1607188.html
Minor Miss Steak
03-25-2013 04:41 PM
