L shape or U shape for stands?
RE: L shape or U shape for stands?
here is a copy and paste of the email I got from them, once I answer they will send out my order:
Thank you for contacting WeRide Enterprises regarding our motorcycle front and rear stand package.
Please let us know what type of supports you need; an explanation follows and pictures are attached to this email for clarification.
As you may already know our stands ship with your choice of one of two different support options: L shaped brackets and U shaped brackets designed for bikes with spools/bobbins on the swing arm.
Most bikes work with the rubber pads which are L shaped brackets that sit under and securely brace your swing arm; because most older model bikes are not outfitted from the factory with screw holes for the spools/bobbins, these L shaped supports are most popular, generally speaking.
The spool/bobbin setup is designed solely for bikes on which extensions that look something like thread spools have been added. These extensions extend outward from the sides of the swing arm. The supports have U shaped brackets that sit under these bobbin type extensions and hold the bike in place.
In summary, newer bikes either ship with spools installed in their swing arms or are at least designed with the screw holes for the owner to install spools because this has become the accepted way to support sport bikes on stands - the older bikes that are not equipped for spools can still be supported by the L shaped pad supports.
For those who already have the spools/bobbins installed or for those who at least already have the screw holes and plan to install the spools/bobbins in their swing arms, the spool/bobbin support is the most popular option because it is easier relative to the rubber pads to use. (Although both options are equally secure and sturdy.)
If your bike has screw holes in the swing arm for the spools/bobbins but you do not already have them to install, we can ship them out to you also. Just let us know that you would also like the spools/bobbins, your color preference (depending on the color of your bike) and we will invoice you for the price via email.
Additionally, if, in the future or now, you would like the option to change the way that your bike is secured on the stands you may order either the rubber pad or spool/bobbin supports separately. Both are interchangeable on our stands. The cost for the additional support is $22 plus shipping (shipping is included if the additional braces are shipped with the original order).
We look forward to sending out your stands.
Keep riding!
--WeRide Enterprises
Thanks guys
-peace Ky
Keep riding!
Thanks guys
-peace Ky
