K & N
RE: K & N
honestly K&N is not what its cracked up to be, do a search on K&N and there is a article i posted somewhere that showed the performance levels of K&N to other brands, and u guess it. K&N was dead last. sure it lets in more air, but what comes with it? dirt. i guess i could sacrifice the extra dirt for that 1- maybe 2 horsepower increase. actually im being sarcastic. Its really not worth it, there are other modifications out there that give you alot more horsepower for your money, and if horsepower isnt a problem then spend all your money on a good suspension set-up. u can have a fast bike, but i would rather have one that can out handle. hope this sheds some light.
RE: K & N
I have a K&N installed. Not for power, but for the ease of cleaning. I like the reusable part of it. You really shouldn't see much improvement from a filter upgrade alone. You need to upgrade the exhaust to use the extra air intake. I've seen a display set up in a car shop that runs non-stop. It's set up with a stock car filter and the K&N in transparent boxes. It directs the air through a tube to lift a ball and the stock one is barley moving while the K&N is flying. And... to answer the dirt question... the stock filter side is filled with dust with the K&N side is still clean. K&N advertisement so do they set up it up for failure on the stock side.... who knows.
RE: K & N
first things first. this thread is in a f4i section and i do not have a f4i but i do have a k&n. so my findings/opinions could be way off.
i too bought the k&n for the wash and reuse factor. this sold me on it. the k&n is less than the price of 2 stock filters. after installing my power commander, i downloaded the map that was right for me. it stated stock or k&n air filter. i read info on the sight that stated if the map had the stock/k&n recommendations, either could be used with that map because there was not enough of a difference to warrent two separate maps. that tells me that the k&n and the stock filter flow close to the same amounts of air. i would still recommend the k&n (or any other reusable filter) to anyone because of the money it saves over the long run. just my opinions.
