just bought f4i
Old Apr 3, 2009 | 09:52 AM
PAf4i's Avatar
Default just bought f4i
i jus bought my bike nd it a lil over 10k on it nd i was wonderin what kind of servicing should i get done on the bike??
-the oil was already changed
-nd i lube the chain regularly
Any help is greatly appreciated.
Old Apr 3, 2009 | 11:29 AM
UncleSmokey's Avatar
Air filter and spark plugs
Old Apr 4, 2009 | 02:24 AM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
What he said, plus coolant, brake fluid, maybe lube the levers.
Old Apr 4, 2009 | 05:13 PM
pr0jktmayhem's Avatar
how much you pick it up for?
Old Apr 5, 2009 | 01:10 AM
Aken's Avatar
July 2008 ROTM
You don't need to replace the air filter or spark plugs at 10k. Coolant and brake fluid couldn't hurt, but not super important. It's best to check as much as you can, though. If the brakes are really squishy and aren't stopping as well, you can redo the fluid (also check the brake pads all around).
Or if you're really **** about it, you can do the whole shebang.
Old Apr 5, 2009 | 04:55 AM
DarkJuic3b0x's Avatar
Normally, I would do the major stuff just to be on the safe side since its your first bike. if you notice minor things, you can always DIY, and if you don;t know how to, the forums have plenty of knowledge... =]
Old Apr 5, 2009 | 06:05 AM
Berto's Avatar
Or if you're really **** about it, you can do the whole shebang.<<
Agree with this. Hondas are so well-engineered for reliability and durability, that's it's possible to over maintain the things and waste money. I just did my plugs and filter at 13K and both were completely unnecesary, based on condition.
Valves? I'd say forget that one too until you get to 20K.
Frequent oil and filter changes--I do about every 3K. Chain cleaning and lube every two weeks, at least. Flush the brake fluid and bleed the systems. You're good to go for many miles.
--Paul
Old Apr 5, 2009 | 06:55 AM
bluej511's Avatar
Brake fluid has to be replaced every 2yrs regardless of mileage. Its hygroscopic. Id do brake fluid every 2yrs no matter what. Especially on a motorcycle and its easy anyways.
superlund
Oct 18, 2010 07:35 PM
allnightsurfsesion
Aug 5, 2010 07:36 PM
gsingletary
Jan 20, 2009 12:13 PM
900rr_Guy
Jun 17, 2007 09:42 AM
CDUBYA
Feb 9, 2007 12:43 AM
