Just Asking-RPM'S?
RE: Just Asking-RPM'S?
ORIGINAL: AnthonyTxL
que?
On mine, her battery dies within a week if I rarely take her over 5k. hrmmm...[&o]
ORIGINAL: ampfp
The alternator is on even at idling... On some badly designed/older bikes the voltage at battery increases when you rev the engine, but I've measured my F4i and even at idling the battery's being charged (>14V). And revving the bike doesnt change the battery voltage much i.e. it's regulated!
sometimes, i rarely go past 5k, i got an 01 with the original battery and it never died on me once yet.
Your stator does have do spin up some to begin charging, usually about 2500 to 3k. You bike has a stator, not an alternator like a car so you are making more voltage the faster you spin the bike, which is why bikes have a regulator/rectifier which essentially turns excess voltage into heat. My 99 F4 had a weird failure of the R/R and it was charging like 22volts at high RPM. This fried the battery and actually melted wiring. Normally when the R/R fails your charing system dies.
ORIGINAL: ddaren
honestly... i stay at around 5000rpm. I tend to baby my bike and keep the stress off the engine as much as possible.
ORIGINAL: ddaren
But that's me. However, ALWAYS look at the driver's next to you. If it's an old person (old women especially), woman, woman on cell phones, and any driver that's sitting up straight 2 inches away from the steering wheel and driving with 2 hands... make sure you get away asap.
If hot girls are next to you, downshift, put ur RPM's to 7000 and just cruise along side them.
lol or put it to second gear and pop a wheelie =]
I doubt if there's a big technology difference between car & bike - finally it's a magnetic field and coil moving relative to each other. The one that's stationary is the stator, the rotating part's the rotor, and the whole thing together is an alternator.
A well designed alternator, then, would put out enough voltage at the lowest rpm's the bike runs. Then as the voltage increases with rev, the regulator sinks the excess power.
If the bike needs to be run at high rpms (anything more than 2500), possibly there's excess voltage drop in the regulator... which might mean a regulator tending toward failure.
