Jacking bike up off the ground
Is it bad to jack the bike up from the exhaust headers? I don't see anywhere else I could jack it unless I remove the exhaust every time.
Should be fine with stock exhaust. Use a block to spread out the pressure point on the headers. I've also use ratchet straps to support the bike from the ceiling. Just don't use your garage door rails - they're weaker than they look.
I'll try and get something back to you tonight on the other stuff we discussed. |
On my Hurricane, I can fit a bock of wood between the exhaust, so the sump takes the weight.
Your not supposed to jack bikes, hence the lack of jack points. Use stands.
Originally Posted by Jaybird180
(Post 1300128)
Originally Posted by boredandstroked
(Post 1300131)
Originally Posted by ShtBiker
(Post 1300133)
Great. That's what I had done so I just wanted to check and see if anyone else had a reason not to.
But stands hold the bike up from the forks and swingarm. Stands won't do what I need if I want to take weight off either of those to do work the suspension. |
Yeah I had it on the rear stand and a block under the exhaust when i started messing with the front end. If I need to do work on the rear I'll probably try to use a front stand and a block in the middle.
(Post 1300135)
Don't forget straps. |
(Post 1300133)
I used to have a full size wheel and tire from my 1993 Nissan Maxima that the bike fit perfectly into at the headers and lifted both ends; balanced pretty decently too. Lack of storage space and a desire to grow out of my bachelor stage prompted me to get rid of the wheel.
