Instrument Cluster not Working
So I randomly went for a ride yesterday and when I turned on the key almost nothing on the instrument cluster was working. On the ride the day before, the cluster was working when I shut off the bike. However, when I started the bike yesterday the blinkers, high beam indicator, and neutral light all worked (but nothing else). Halfway through my ride, the neutral light stopped working also, but the blinkers and highbeam indicator still works.
I found it strange that the neutral light randomly stopped working, but some of the indicator lights still worked. This made me think that it's not a loose connector, but I'm still not sure. I was wondering if you guys had any ideas before I started tearing into the bike. Riding without a tach or speedo is not the best idea...
EDIT: I should also add that the clock and trip meter never worked properly. Every time I shut the bike off and turned it back on they would reset themselves. Not sure if that would have anything to do with this...
Not readily accessible, but would a weak battery cause the cluster to not work while the bike is running? I didn't think that it would...
Does your bike have flush mount signals? I just installed some the other day and my cluster fuse kept blowing. I would have the hi beam indicator and turn signal indicators but no speedo or tach. As it turned out I had some wires crossed up. If you have flush mounts its worth a look at the wiring.
ps-after correcting my flush mount problem, I now have no fuel injection at all. Any suggestions?
