ignition help
ignition help
I have zero spark. The only fire I can find at the primary coil harness and ecm is the black and white wire. Battery is good, bas is bypassed correctly, ignition switch is good, engine stop switch is good, kickstand switch is fine, all the easy stuff seems alright. Any suggestions would be great. Thanks
RE: ignition help
check your tip over sensor behind the windshield. i bought a 01 f4i and was told the cdi box was bad after buying a cdi box it still didnt have fire come to find out the tip over sensor had been installed upside down by some shop. I turned it over and the bike got fire not to say yours is upside down but check it. also there was a write up on here about bypassing it
