idling is too high
#31
#34
ok. i got the wax unit taken off and noticed one of the hose openings to be stuffed with light bluish stuff. i did the test with the hot water on it and it didnt work, meaning the rod did not extend. i tried to take it apart to clean it but the screws were so tight i happened to strip them a bit, so i guess replacing the unit would fix the issue.
#35
#36
i didnt know i could ride it w/o the wax unit.. but i think i'll wait for the part to put everything together cuz it was a pain in the butt to get to where i am rightnow
#38
#39
did you leave the wax unit in the boiling water for a minute or two? it will take a couple minutes to heat the wax... anyways, a faulty wax unit would explain the high idle, i'm sure that's it.
Maybe that blueish crap is the was leaking out... idk, never taken one of those apart. It being plugged would explain coolant not getting in there to heat the wax.
#40
