i SCREWED up!
The air intake cover screw that goes into the tank is different. It is metallic silver in color and larger in diameter.
i believe it is a truss screw for your lower fairing: the V shaped piece of plastic in front of the radiator. also known as SCREW, TRUSS (5X16) part number 90109-SB6-000. I have a stash of them in my garage. there's only 3 different type of screws that i know of on the F4i (but i'm sure there's more) : airbox, truss, and throttle body clamp screws. that is not a TB screw.
Can anyone tell me what you have on your front inner fairing? Screw number -vs- clip number?
I believe you said there were only two screws like this on the front inner cowl. I may have erroneously discounted your theory based on this. If you are the first to tell me how many screws vs body clips connect the front inner fairing to the side fairings and the front fairing then you may indeed end up with the prize money......
