I Got My Frame Sliders Installed
There all finished up, now all that I need are my signals to put it all back together.
The right side turned out perfect, but the left side is a little off, but nothing to worry about. I used a laser level which seemed to be the easiest way. Its not as hard to do as I thought it would be.
Its just too bad the previous owner didn't have them on before he went down, it would have saved me alot of work replacing covers and repainting when I get to it.
-Jesse-
-Jesse-
RE: I Got My Frame Sliders Installed
It came off really easy. If I have to I'll pull the sides back off to make it easier. All I need to do now is install the signals if I get them and decide wheather to replace the stator cover of sand and paint it. Then polish it all up and I'm ready to ride in the spring. Thanks
-Jesse-
-Jesse-
Thanks for the compliments, I was so nervious before I cut the first one LOL. I had to check and double check before I cut into it. After that it was all good. I just wish the left side would have turned out as good as the right but you can't really tell.
pitsvtech- I really haven't heard anything good about the no cuts, so I just decided to go and cut it up. If I messed it up I wasn't too worried about it beacuse I'm going to repaint next winter so I could have patched it up until then.
-Jesse-
-Jesse-
