I changed my oil and then...
I noticed a slight rattle from the front of the bike when I would rev it up. It wont make the sound when I rev it really slow, but when I blip the throttle it will make a rattle for just a quick second then it goes away almost immediately. I used the 5w-30 Synthetic Rotella-T (blue jug) and the Supertech ST7317.
Also, I was tightening the oil filter back on and wasnt thinking about what I was doing...I had a plastic filter wrench and tightened it until the wrench wouldnt hold ...I tried to back it off and do it correctly but the wrench couldnt hold it enough to back it out...Is this a problem? I was thinking since the wrench I have was plastic, perhaps a metal filter wrench would hold it better and let me loosen it to the correct torque.
I also noticed that the bike idles at like 1200 RPMs as opposed to the 1500 I had it set on before. I believe the previous owner used the Honda oil, since he had a Honda filter on there. Would using the Rotella-T oil have anything to do with that?
Incognito:
I went down with the pliers and absolutely destroyed the filter trying to get it off...it was leaking all over the place because I had to clamp down so hard to get it off...damn that thing was on GOOD! I went back to WM and got another filter and put it on, hand tight this time. The sound is still there...at least I know the filter is on right tho. I ran the bike a little bit in my garage and will check the oil level tomorrow...not much came out from the old filter, I may have to replace .3 qt at the most.
Don F4i:
I misspelled...It is 5w-40. Its the blue jug Rotella that everyone one here recommends.
Why would it start right after I changed the oil tho if it is the CCT. I have had a very quiet vibration noise at 5k RPM since I bought the bike this spring. But I have never had the noise at the bottom end until right after the oil change... weird.
Don F4i:
Plus, if it was putting extra stress on the oil pump I wanted that fixed.
I also learned that the extra minute to remove the right fairing is WELL worth it.
Learning as I go.
No big deal, at least you're using Supertechs which are cheap. Guess I forgot to mention the pliers mangle the thin walled filters. I'm going to agree with DonF4i, more than likely it's not the oil pump. You know, my bike makes strange noises sometimes. If you sit there with the engine running intently listening to it, you're bound to find something that sounds weird. But is one supposed to tear the thing apart in an attempt to find "that" ticking sound? Give it a couple of days; it'll go away, lol.
There was one fella here who heard a ticking sound which over time, progressively got worse. He took the valve cover off to check the valves, and discovered that one of his cam journals (no.1 cylinder) wasn't receiving any oil, thus it scored the aluminum pretty badly. Ended up having to replace the entire head. Not to make you paranoid or anything, but...
Change the oil first and have less mess.
(Speaking from a guy that changed his oil, but couldn't torque the filter off, so he's 500 mile in with new oil but an old filter...) New question: Now, can I get away with THAT?
